Preamplifiers (LNAs), low/high/bandpass/notch filters, Bias-T units and other RF "building blocks"
https://gpio.com/
HTH
RF building blocks
Re: RF building blocks
an example
https://gpio.com/collections/low-noise- ... -30db-gain
the LNA above should fit pretty well the SULA loop
Mmm 30dB, 2.2dB noise, sounds very tempting. I should try that when I get to make the small version of the SULA!
then one may add some filters
https://gpio.com/collections/notch-filters
between the antenna and the LNA in EU or at Least in Italy one may want this
https://gpio.com/collections/notch-filt ... ction-85db
to keep commercial FM from.saturating the LNA and deafening it or the receiver frontend
