Improving the MLA-30
Here are some suggestions, in case you decided to buy it, that is :)
First step, improve the loop; either use some copper pipe or alumium strip to make a wider and BIGGER loop (easy)
Second step; match the impedance, the preamp has an impedance ranging from 1.5K down to 450Ohm, now ler's find a balance, break the loop at top and use a 975Ohm resistor to connect the two halves
Third step: the preamp to bias tee coax sucks badly, add a BNC connector to the preamp box and use a run of decent coax (RG6 will do) to feed the loop
Fourth step: the BIAS Tee unit was designed by a drunk folk, replace it asap
Re: Improving the MLA-30
Post by Egil - LA2PJ »
Never used a MLA-30 myself, but today I more or less stumbled over this discussion where they also have published schematics for both loop amplifier and bias-T:
https://www.eevblog.com/forum/rf-microw ... p-antenna/
Good luck!
Yep Egil, know that, all in all I wrote that post :D
