Another directional RX loop
Re: Another directional RX loop
Also, a DUE note !
The idea came after a request from my dear friend Kostas (SV3ORA); he asked me if it was possible to make the "SULA" smaller and less visible (basically it shouldn't look like an antenna) and told me that ideally he needed some given dimensions
At first, knowing all the hurdles and issues I faced while designing and optimizing the "SULA" I told him that it wouldn't be possible or, better said, that such a reduced size antenna wouldn't offer acceptable performance at lower frequencies, but then... being the kind of "hard headed" folk I am, I told myself... why not, let me try
So after some fiddling with NEC, changing designs, mailings (with Kostas), scratching head... ok, all the usual "process", I finally came out with the design you tried, and given your results, it seems to work decently well :D
A request, if I can dare; would you be so kind to try the "nulling" of the antenna ? I mean, aim it at some given station, then record the signal and try turning the antenna so that its backside "NULL" will be oriented toward the station; does it really "cancel out" the station or, in any case, is there a noticeable signal attenuation (as I think it should be) ?
Post by Egil - LA2PJ »
Andrew (grayhat) wrote: Wed May 15, 2024 1:28 pm If you can/want, it will be interesting to see a video comparing that antenna with the stock one (or with some other antenna)
Right now I am in Trondheim, but I am planning to do just that when I return home at the end of this month.
Forgot to say that I made the SULA made with some break line had had at hand, and placed 3m above ground on a small rotator. But I hadn't made it strong enough mecanicly, so one of the winter storms pulled it apart. It was a really good receiving antenna, so I plan to make a new one with more sturdy materials, so it can survive the harsh winter weather on an island on the west coast of Norway.
Egil - LA2PJ wrote: Wed May 15, 2024 3:30 pm
The "squished SULA" (the rectangular loop) may be a good candidate for harsh weather conditions, if built using a pipe (see the images I posted) it will offer very small surface to wind so may possibly survive those winter storms (notice, the pic at the link below is not up to scale, the support between the antenna and the mast may be as short as say 20...30cm)
viewtopic.php?p=960#p960
anyway, I'm really interested in knowing how well the "squished SULA" nulls out stations so, if possible, rotating it to "null out" a station and reporting results will be really useful and interesting
Andrew (grayhat) wrote: Wed May 15, 2024 3:46 pm
That is exactly what I also have been thinking. But right now I'm recovering after beeing hit and severly injured by a car at a pedestrians crossing.
So at the moment I have some mobility problems and have to use a walker or crutches. The doctor indicate another six to eight weeks before I'm back to normal, so to kill a rather boring time, I'm studying how to make my antennas "weather resistant".
The original SULA was a rather good receiving antenna the few weeks it survived. But the squashed version pinned to the inside loft, using the same balun and preamplifier in my opinion worked very similar to the original. So my plan when I am back to normal is to make one of each of the antennas and try to compare them. I already have an extra balun and have ordered an extra preamplifier.
And I think your idea using a wide pipe to support the squashed antenna is very good.
It will take some time, but I'll report here when I'm back on my feet and able to play properly with these antennas. So now you know why I had to make the antenna inside the house. Must admit that this is fun!
OMG, hope you'll get better soon !!
As for the antennas, I believe that the "pipe" may be able to survive harsh weather better than the SULA, if you look at the image, you'll notice that everything is enclosed/protected by the pipe, including the coax connector, and then the pipe is small enough (assuming the original sizes are used) to stand to winds w/o issues, plus given the geometry, it's possible to use a lightweight antenna rotator to aim it
A note, since you currently have the antenna aimed at a fixed spot, if you want, you may find a station which is "at the back" of the antenna using the wire antenna or the whip of the receiver, and then with such a station tuned, use the small loop to check if the signal disappears or is strongly attenuated (as it should be)
For the interested ones, here's another idea to build the compact loop, the attached image shows all the relevant details, the resistor may be a regular one (although a non inductive one would be better), the 9:1 can be the commercial NooElec BalUn or can be built using a #73 binocular core, the PVC pipe encloses the antenna and the other components protecting them from atmospheric agents, the bottom part of the pipe (below the loop to avoid unwanted coupling) is tied to the support pole using steel cable ties and nuts+bolts (not shown in the drawing), the antenna should be installed at least at 1.5...2 meters from roof or ground; choosing a gray PVC pipe the resulting antenna may be easily disguised as a "weather station sensor" for the ones living in "antenna restricted" areas (read HOA) ;) also, the antenna is unidirectional (cardioid pattern) so it must be aimed to the desired direction, willing to use a rotator, a small one, like the ones used for TV antennas will fit, also since the antenna offers pretty low "load" against the wind, the top and bottom caps and the holes used for the nylon ties supporting the loop wire must be sealed using silicon or other suitable sealant to avoid issues due to humidity (rain, mist, fog) or due to ... insects :) the pipe is 200x2000 mm but if needed it may be shortened a bit or, willing to build a portable version, it may be spliced in two or three sections to ease carrying the antenna
Can't wait to make and try one of those! (Will take a while tho.) :mrgreen:
13dka wrote: Sun Apr 27, 2025 8:46 am Can't wait to make and try one of those! (Will take a while tho.) :mrgreen:
tried it, works as described, less gain than the SULA but much easier to carry around and for permanent setups more resistant to winds
