Sony SW100
Icon
Sony SW100
Post by Icon »
I have repaired several of these, but came across an issue I have never had before, and not sure, but am thinking it's the cable ribbon, but then again, not sure that each row of buttons has it's own separate connection. .
The 4 5 and 6 buttons do not work, but all other number and control buttons do. I probably have enough spare parts to fix the issue, but if it's not the ribbon, what else might I look at? I don't want to have to take it apart several times changing parts to find the problem, so any advice is a plus.,
Icon
Re: Sony SW100
Post by Icon »
Had to change out the keypad.... works great now.
Re: Sony SW100
if you don't have it, here's the service manual
https://www.manualslib.com/manual/38346 ... Sw100.html
which may be useful for repair/realignment
Icon
Re: Sony SW100
Post by Icon »
Thank you much for that.. Learning to change parts, or replace ribbons is easy, as long as I can see the problem, or just change parts till it fixes the issue.
May see if I can print that manual, as it's easier for me to use printed material than to scroll thru pages on a screen..
